Boot from USB 3.0 with hub
Hello
As storage is going sparse on my Rock64, I would like to put my bootdrive, an Sata SSD connected over an USB 3.0 to Sata bridge, behind an USB 3.0 hub.
However, as soon as I try to boot with this setup, I get the following error in the U-boot console and the rock64 is trapped in a bootloop.
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... WARN halted endpoint, queueing URB anyway.
Unexpected XHCI event TRB, skipping... (fcf14530 00000000 13000000 02008401)
"Synchronous Abort" handler, esr 0x96000210
ELR:    fef60008
LR:      fef60008
x0 : 0000000000000000 x1 : 00000000000003e8
x2 : 0000000000000040 x3 : 000000000000003f
x4 : 00000000fcf14910 x5 : 0000000000000031
x6 : 00000000fef8846c x7 : 000000000000000f
x8 : 00000000fcf02ac0 x9 : 0000000000000008
x10: 00000000fcf02775 x11: 0000000000000008
x12: 00000000ffffffff x13: 00000000000035c8
x14: 00000000fcf049cc x15: 0000000000000008
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000fcf0ce08 x19: 00000000fcf13240
x20: 00000000fcf03240 x21: 0000000000000000
x22: 00000000fcf1dad0 x23: 0000000000000000
x24: 00000000fcf02f00 x25: 0000000080000383
x26: 0000000000000002 x27: 0000000000000001
x28: 00000000fcf02dc0 x29: 00000000fcf02c40
Resetting CPU ...
My current setup, in which USB booting works is the following. I use a rock64 v2, on which I've flashed ayufans Uboot fork, version 2017.09-rockchip-ayufan-1065-g95f6152134 from April 2020. (newest version). Boot device is a sata SSD connected directly to the USB 3.0 port with an USB to Sata Bridge.
Does somebody had maybe similiar problems or know a solution? According to my research, there should be a U-boot module which allows to use USB-hubs (PATCH v2 00/15, see here), however it is not clear for me, if this patch is integrated in ayufans U-boot. Or does somebody know another U-boot fork allowing the usage of USB hubs for boot devices?
I know that this question is a bit strange, and that the setup seems utterly complicated, however I have to stall a bit until the rockpro64, my new dream server board, will be back in stock again Smile
Thank you very much for answer.
Best regards
Turbo
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 627 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,787 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,052 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,581 03-23-2021, 04:51 AM
Last Post: kiriakos
  Unable to boot armbian fchazal 2 3,866 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,436 05-19-2020, 06:38 PM
  Help me understand the boot up process olivercfc 0 1,931 11-10-2019, 08:30 AM
Last Post: olivercfc
Brick Rock64 stuck in boot, please help! Malmgren 7 8,718 11-05-2019, 07:02 AM
Last Post: Malmgren
