Help me understand the boot up process
I'm obviously missing something fundamental here.
I built an image with buildroot which creates a u-boot-tpl-spl.img, a u-boot.itb file and a root partition
        image = "u-boot-tpl-spl.img"
        offset = 32768 # 512 * 0x40 from start of sd card
        image = "u-boot.itb"
        offset = 262144 # 512 * 0x200 from start of sd card
        bootable = "yes"
        image = "rootfs.ext2"
In the rootfs partition there's a file called /boot/extlinux.conf which has the following
label rock64-buildroot
  kernel /boot/Image
  devicetree /boot/rk3328-rock64.dtb
  append console=ttyS2,1500000n8 root=/dev/mmcblk0p1 ro rootwait
This boots up and all is good.  However, I'm wondering why I can't just replace /boot/Image and /boot/rk3328-rock64.dtb (and /lib/modules/*) with the one from slack (for example) and have that boot up.
When I tried, it didn't find /boot/Image and tried to boot off the network.
What am I missing here?
  Rock64 won't boot dstallmo 0 321 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 578 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 608 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,718 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,035 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,548 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,091 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,839 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,403 05-19-2020, 06:38 PM
Brick Rock64 stuck in boot, please help! Malmgren 7 8,659 11-05-2019, 07:02 AM
Last Post: Malmgren
