Rock64 + Klipper + KlipperScreen Instructions
    Rock64 + Klipper + Fluidd + KlipperScreen
After much ado I finally got everything working. I tried many flavors of linux and the only one that had decent video drivers was Ayufan's prerelease version 0.11.2.-1187.
I purchased several Rock64's some years ago for $20 off amazon. It was a security appliance with power supply. Used a couple for retro gaming. Next to print enclosure and mounting.
Here's what you need. (I supplied links at the end)
*Rock64
*Linux Favor Ayufan= focal-minimal-rock64-0.11.2-1187-arm64.img.xz or newer.
*klipper screen = Kuman 7" HDMI 1024x600 - Amazon or aliexpress
*Download Kiauh and follow instructions. Seems all manual installs have been removed for search engines.
KlipperScreen Error I encountered -
xf86OpenConsole: Cannot open virtual console 2 (Permission denied)
Fix that worked ->
sudo bash -c "echo needs_root_rights=yes>>/etc/X11/Xwrapper.config"
Some xorg random notes -
find monitor number via ssh do not type $
$ export DISPLAY=:0
$ xrandr --listmonitors
list display resolutions
$ xrandr -d :0
$ xrandr -display :0.0 --listmonitors
>output
Monitors: 1-- 0: +*HDMI-1 1920/476x1080/268+0+0  HDMI-1
Links
Klipper Screen Error & fixes
http://klipperscreen.readthedocs.io/.../.../VC_ERROR/
Ayufan Rock64 Home
github.com/ayufan-rock64/ayufan-rock64.github.io
Ayufan Rock64 0.11.2 Download page (scroll down)
github.com/ayufan-rock64/linux-build/releases/tag/0.11.2
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 157 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 340 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 623 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,455 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,865 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 597 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 654 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,488 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 941 08-29-2022, 01:22 PM
Last Post: ramprasad
