Using multiple UART's on Rock64.
We are currently using UART on pins 8,10 for serial console. Based on the pin diagram, there are 2 more UART's available. One set on pins 15,18 and another set on pins 33,35 which is currently used for SD card slot. We are using Ayufan's Linux kernel release-4.4.167.
We are using EMMC and SD card slot is unused. So we want to disable it and use the UART functionality instead.
How can we configure these pins to be used as UART's. Is it possible to do with dtb overlay ? Is there any User guide or manual which could guide us with this configuration ?
Also what is the max baud rate that can be achieved on these UART's ? The one used for console port is 1500000 bauds.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,150 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 2,221 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,305 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,290 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,252 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,357 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,545 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,491 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 88,218 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 111,520 09-01-2024, 06:05 AM
