HDMI doesn't work on rock64
HDMI doesn't work with any Kernel except the Kernel 4.4 from Rockchip (it also doesn't work with xorg) i tried out all kernel configs from rockchip and ayufan always same error:
[    4.030085] printk: console [ttyS2] enabled
[    4.031672] rockchip-vop ff370000.vop: Adding to iommu group 1
[    4.038101] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffffc0108c27d8)
[    4.038924] rockchip-drm display-subsystem: failed to bind ff3c0000.hdmi (ops 0xffffffc0108c5f30): -517
[    4.040292] rockchip-drm display-subsystem: master bind failed: -517
With Kernel 4.4 from Rockchip (ayufan) HDMI works:
[    3.167892] [drm] Initialized drm 1.1.0 20060810
[    3.173651] [drm] Rockchip DRM driver version: v1.0.1
[    3.174380] rockchip-drm display-subsystem: devfreq is not set
[    3.175647] rockchip-drm display-subsystem: bound ff370000.vop (ops 0xffffff8008d86950)
[    3.176798] i2c i2c-4: of_i2c: modalias failure on /hdmi@ff3c0000/ports
[    3.177487] dwhdmi-rockchip ff3c0000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.178358] dwhdmi-rockchip ff3c0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (inno_dw_hdmi_phy2)
[    3.180400] rockchip-drm display-subsystem: bound ff3c0000.hdmi (ops 0xffffff8008d7afa8)
[    3.181186] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.181851] [drm] No driver support for vblank timestamp query.
[    3.182495] rockchip-drm display-subsystem: failed to parse display resources
[    3.402118] rockchip-vop ff370000.vop: [drm:vop_crtc_enable] Update mode to 1280x1024p60, type: 11
[    3.469911] Console: switching to colour frame buffer device 160x64
[    3.503468] rockchip-drm display-subsystem: fb0:  frame buffer device
Xorg-log:
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.14.89-0-vanilla aarch64 Alpine Linux
Current Operating System: Linux localhost 5.4.2 #1 SMP Thu Dec 12 03:04:42 CET 2019 aarch64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.2 modules=loop,squashfs,sd-mod,usb-storage modloop=/boot/modloop-5.4.2 extra_latent_entropy1
Build Date: 31 May 2019  06:21:31AM
Current version of pixman: 0.38.4
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 21 10:28:08 2016
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
MESA-LOADER: failed to open rockchip (search paths /usr/lib/xorg/modules/dri)
failed to load driver: rockchip
MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/xorg/modules/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /usr/lib/xorg/modules/dri)
failed to load swrast driver
couldn't get display device
(II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Unsupported high keycode 372 for name <I372> ignored
>                   X11 cannot support keycodes above 255.
>                   This warning only shows for the first high keycode.
> Internal error:   Could not resolve keysym XF86MonBrightnessCycle
> Internal error:   Could not resolve keysym XF86RotationLockToggle
Errors from xkbcomp are not fatal to the X server
(EE) /usr/share/libinput: failed to find data files
(EE) Failed to load the device quirks from /usr/share/libinput and /etc/libinput/local-overrides.quirks. This will negatively affect device b.
/usr/bin/startxfce4: X server already running on display :0
<stdin>:0: warning: Unknown encoding: C.UTF-8
    xfce4-session: No GPG agent found
xfce4-session: No SSH authentication agent found
(xfce4-session:2231): xfce4-session-WARNING **: 10:28:10.365: xfsm_manager_load_session: Something wrong with /home/admin/.cache/sessions/xfc?
(xfwm4:2278): GLib-CRITICAL **: 10:28:19.096: g_str_has_prefix: assertion 'prefix != NULL' failed
(xfsettingsd:2284): GLib-CRITICAL **: 10:28:20.459: g_str_has_prefix: assertion 'prefix != NULL' failed
(xfsettingsd:2284): GLib-GObject-CRITICAL **: 10:28:20.721: g_value_get_string: assertion 'G_VALUE_HOLDS_STRING (value)' failed
(xfsettingsd:2284): GLib-GObject-CRITICAL **: 10:28:20.800: g_value_get_string: assertion 'G_VALUE_HOLDS_STRING (value)' failed
Error relocating /usr/bin/Thunar: pango_attr_insert_hyphens_new: symbol not found
xfsettingsd: No window manager registered on screen 0.
xfce4-panel: No window manager registered on screen 0. To start the panel without this check, run with --disable-wm-check.
No window manager registered on screen 0. To start the xfdesktop without this check, run with --disable-wm-check.
xfce4-panel-Message: 10:28:33.334: Plugin "statusnotifier-7" was not found and has been removed from the configuration
xfce4-panel-Message: 10:28:33.338: Plugin "pulseaudio-8" was not found and has been removed from the configuration
xfce4-panel-Message: 10:28:33.377: Plugin "notification-plugin-10" was not found and has been removed from the configuration
** (wrapper-2.0:2315): WARNING **: 10:28:36.247: No outputs have backlight property
(wrapper-2.0:2315): xfce4-power-manager-plugin-WARNING **: 10:28:36.920: Xfce4-power-manager: The panel plugin is present, so the tray icon g.
(wrapper-2.0:2315): Gtk-WARNING **: 10:28:37.092: Negative content width -3 (allocation 1, extents 2x2) while allocating gadget (node button,)
(xfdesktop:2311): GLib-GObject-CRITICAL **: 10:28:46.065: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
^Cxinit: connection to X server lost
waiting for X server to shut down ^VGdk-Message: 10:28:59.978: xfdesktop: Fatal IO error 38 (Function not implemented) on X server :0.
Gdk-Message: 10:28:59.978: xfsettingsd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
I boot with extlinux.conf: The kernel starts only without console bootparameter: When i insert console=tty0 as boot paramter the kernel dont start.
Does anyone know what the problem could be.
Thank you in advance for your help
Sorry, but Kernel 4.4 is pretty obsolete.
Most distros using Kernel 6.x now and HDMI Video and Audio works just fine.
Try Debian 12 Bookworm or Manjaro (select ARM and then the Rock64 from the drop down menu).
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 157 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,374 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 340 12-27-2023, 10:34 AM
Last Post: dstallmo
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 620 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,466 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,894 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 599 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 654 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,489 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 941 08-29-2022, 01:22 PM
Last Post: ramprasad
