Read-only problem
So i have a problem ...
My rock is on 24/7, some weeks ago i had every day the next error when i wanted to execute a sudo command
sudo: unable to open /var/lib/sudo/ts/rock64: Read-only file system
The only thing i can do to fix it is a reboot.
So after a week i changed the eMMC ....
It was good for 3 weeks but now is the problem back anyone an idea what the problem can be ?
I have 4GB rock + 32GB eMMC and running stretch-minimal-rock64-0.5.15-136
Are you maybe running out of space? What else is on in the logs?
Space is not the issue, only 5GB in use ...
I'm now looking in to kern.log and find this from the last days before read-only-"crash"
Apr  1 20:37:12 MDserver64 kernel: [1038414.257579] EXT4-fs (mmcblk0p7): error count since last fsck: 4
Apr  1 20:37:12 MDserver64 kernel: [1038414.266661] EXT4-fs (mmcblk0p7): initial error at time 1520438366: ext4_journal_check_start:56
Apr  1 20:37:12 MDserver64 kernel: [1038414.275943] EXT4-fs (mmcblk0p7): last error at time 1520447884: ext4_remount:4710
Apr  2 20:38:59 MDserver64 kernel: [1124923.760669] EXT4-fs (mmcblk0p7): error count since last fsck: 4
Apr  2 20:38:59 MDserver64 kernel: [1124923.779625] EXT4-fs (mmcblk0p7): initial error at time 1520438366: ext4_journal_check_start:56
Apr  2 20:38:59 MDserver64 kernel: [1124923.798711] EXT4-fs (mmcblk0p7): last error at time 1520447884: ext4_remount:4710
Apr  3 07:34:54 MDserver64 kernel: [1164279.633485] mmcblk0: error -110 sending status command, retrying
Apr  3 07:34:54 MDserver64 kernel: [1164279.664787] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
Apr  3 07:34:54 MDserver64 kernel: [1164279.674269] mmcblk0: status not valid, retrying timeout
Apr  3 12:49:29 MDserver64 kernel: [1183155.075634] mmcblk0: error -110 sending status command, retrying
Apr  3 12:49:29 MDserver64 kernel: [1183155.101534] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
Apr  3 12:49:29 MDserver64 kernel: [1183155.120492] mmcblk0: status not valid, retrying timeout
Also here is the startup log (i'm not so good at it :p )
https://pastebin.com/VVdr2fC0
So this is also from today
Apr  4 17:54:50 MDserver64 kernel: [86809.605166] EXT4-fs (mmcblk0p7): error count since last fsck: 6
Apr  4 17:54:50 MDserver64 kernel: [86809.624101] EXT4-fs (mmcblk0p7): initial error at time 1520438366: ext4_journal_check_start:56
Apr  4 17:54:50 MDserver64 kernel: [86809.643169] EXT4-fs (mmcblk0p7): last error at time 1522763019: ext4_journal_check_start:56
Ok that looks more like the filesystem dropped into read-only mode because of the block device errors, maybe bad eMMC?
that would be 2 out of 2 i bought here on pine64.com Sad
Can i clame warrenty ?
Nobody else with the same problem ?
(04-04-2018, 11:53 PM)mikedhoore Wrote: that would be 2 out of 2 i bought here on pine64.com Sad
I'm having the same problem, did you find a solution?
  problem with debian emmc boot G4zCDzWb 10 12,785 11-01-2024, 04:32 PM
Last Post: bits
  Rock64 Debian 11 (Bullseye) install problem jbize 15 22,694 10-12-2023, 05:14 PM
Last Post: tpaul
  External hard drive problem k8Va 17 34,873 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 5,081 08-17-2020, 10:35 AM
Last Post: max
Question bluetooth rock64 problem deta 3 8,171 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 6,895 01-20-2020, 12:25 PM
Last Post: kf5zmi
  ROCK64 Kernel compilation problem cao 0 3,716 01-21-2019, 01:21 AM
Last Post: cao
Lightbulb Wifi problem Nether494 13 28,457 11-28-2018, 01:48 PM
Last Post: Nether494
  Problem with time in rock64 gedas07 2 7,041 11-12-2018, 12:07 PM
Last Post: gedas07
  WiFi on Armbian problem scalextrix 14 29,486 09-08-2018, 01:13 AM
Last Post: scalextrix
