ROCK64 Kernel compilation problem
I had a problem compiling the rock64 kernel(https://github.com/rock64-linux?tab=repositories),
Buiding kernel and u-boot image: build/mk-kernel.sh rk3328-rock64(build/mk-uboot.sh rk3328-rock64)
The current uboot partial compilation is OK。
 Building kernel for rk3328-rock64 board!
 Using rockchip_linux_defconfig
# configuration written to .config
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CHK     include/generated/utsrelease.h
  CHK     include/generated/timeconst.h
  CHK     include/generated/bounds.h
  CHK     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
make[1]: 'include/generated/vdso-offsets.h' is up to date.
  CHK     include/generated/compile.h
  CC      arch/arm64/kernel/topology.o
  CC      block/elevator.o
  CC      crypto/ablk_helper.o
arch/arm64/kernel/topology.c: In function ‘parse_cluster’:
arch/arm64/kernel/topology.c:133:40: warning: ‘%d’ directive output may be truncated writing between 1 and 10 bytes into a region of size 3 [-Wformat-truncation=]
error, forbidden warning: topology.c:133
scripts/Makefile.build:258: recipe for target 'arch/arm64/kernel/topology.o' failed
make[1]: *** [arch/arm64/kernel/topology.o] Error 1
Makefile:983: recipe for target 'arch/arm64/kernel' failed
make: *** [arch/arm64/kernel] Error 2
make: *** Waiting for unfinished jobs....
  GZIP    kernel/config_data.gz
  CC      kernel/relay.o
crypto/ablk_helper.c: In function ‘ablk_init’:
crypto/ablk_helper.c:144:49: warning: ‘%s’ directive output may be truncated writing up to 63 bytes into a region of size 55 [-Wformat-truncation=]
error, forbidden warning: ablk_helper.c:144
scripts/Makefile.build:258: recipe for target 'crypto/ablk_helper.o' failed
make[1]: *** [crypto/ablk_helper.o] Error 1
Makefile:983: recipe for target 'crypto' failed
make: *** [crypto] Error 2
  CC      drivers/cpufreq/rockchip-cpufreq.o
block/elevator.c: In function ‘elv_register’:
block/elevator.c:839:14: warning: ‘snprintf’ output may be truncated before the last format character [-Wformat-truncation=]
error, forbidden warning: elevator.c:839
scripts/Makefile.build:258: recipe for target 'block/elevator.o' failed
make[1]: *** [block/elevator.o] Error 1
Makefile:983: recipe for target 'block' failed
make: *** [block] Error 2
kernel/relay.c: In function ‘relay_create_buf_file’:
kernel/relay.c:420:35: warning: ‘snprintf’ output may be truncated before the last format character [-Wformat-truncation=]
error, forbidden warning: relay.c:420
scripts/Makefile.build:258: recipe for target 'kernel/relay.o' failed
make[1]: *** [kernel/relay.o] Error 1
Makefile:983: recipe for target 'kernel' failed
make: *** [kernel] Error 2
^CTraceback (most recent call last):
  File "./scripts/gcc-wrapper.py", line 102, in <module>
    scripts/Makefile.build:403: recipe for target 'drivers/firmware' failed
scripts/Makefile.modbuiltin:54: recipe for target 'drivers/gpu/arm/mali400/ump' failed
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,955 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,381 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,143 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,212 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,807 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,836 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,106 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,307 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  How to boot an older, working kernel bits 0 3,169 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 31,169 11-01-2024, 04:32 PM
Last Post: bits
