bluetooth rock64 problem
Question
hello,
I had to set up my Rock64 a few days ago because the SD card had unfortunately died.
As always, I first installed a new SD card with the image "Armbian_20.02.1_Rock64_buster_current_5.4.20". Everything great. Only my bluetooth stick does not want to run.
I don't have a desktop version, only access via SSH
The stick is recognized, as before. Here are a few system information:
root@rock64:~# lsusb
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0451:16a8 Texas Instruments, Inc.
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@rock64:~#
root@rock64:~# dmesg | grep -i bluetooth
[34669.643396] Bluetooth: Core ver 2.22
[34669.643482] Bluetooth: HCI device and connection manager initialized
[34669.643498] Bluetooth: HCI socket layer initialized
[34669.643506] Bluetooth: L2CAP socket layer initialized
[34669.643522] Bluetooth: SCO socket layer initialized
root@rock64:~#
root@rock64:~# hcitool scan
Device is not available: No such device
root@rock64:~#
root@rock64:~# hcitool dev
Devices:
root@rock64:~#
Why is the stick not recognized with hcitool?
What else can I do?
What is missing ?
cu Deta
I wonder if you boot without the dongle plugged in and plug it in after the boot completes
(05-01-2020, 11:45 AM)Rocklobster Wrote: I wonder if you boot without the dongle plugged in and plug it in after the boot completes
ok
have now switched off the Rock64, pulled the dongle and switched on.
root@rock:~# sudo service bluetooth status
● bluetooth.service - Bluetooth service
  Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
  Active: inactive (dead)
    Docs: man:bluetoothd(8)
root@rock:~# sudo /etc/init.d/bluetooth start
[ ok ] Starting bluetooth (via systemctl): bluetooth.service.
root@rock:~# sudo /etc/init.d/bluetooth status
Mai 05 14:41:56 rock systemd[1]: Condition check resulted in Bluetooth service being skipped.
root@rock:~# hcitool dev
Devices:
root@rock:~#
Now I put the dongle back in.
   Active: active (running) since Tue 2020-05-05 14:44:18 CEST; 2s ago
 Main PID: 12311 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4746)
   Memory: 2.4M
   CGroup: /system.slice/bluetooth.service
           └─12311 /usr/lib/bluetooth/bluetoothd
Mai 05 14:44:18 rock systemd[1]: Starting Bluetooth service...
Mai 05 14:44:18 rock bluetoothd[12311]: Bluetooth daemon 5.50
Mai 05 14:44:18 rock systemd[1]: Started Bluetooth service.
Mai 05 14:44:18 rock bluetoothd[12311]: Starting SDP server
Mai 05 14:44:19 rock bluetoothd[12311]: kernel lacks bnep-protocol support
Mai 05 14:44:19 rock bluetoothd[12311]: System does not support network plugin
Mai 05 14:44:19 rock bluetoothd[12311]: Bluetooth management interface 1.14 initialized
Devices:
root@rock:~#
The Same...
Mh i think that is the Problem
root@rock:~# sudo modprobe btusb
modprobe: FATAL: Module btusb not found in directory /lib/modules/5.4.32-rockchip64
root@rock:~#
  rAudio for Rock64 V2 shinzuka 9 1,226 06-05-2026, 06:22 AM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 18,348 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 970 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,738 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,651 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,094 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,267 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 12,278 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,309 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 85,323 09-01-2024, 06:43 AM
Last Post: RaymondDay
