Arch Linux Arm - external RTC problem
I have connected an external RTC module (ds3231) to a Rock 64/4g.
I've loaded i2c-dev modules and rtc-ds1307 modules but my rtc mod is not detected by i2c (i2cdetect shows nothing connected at address 68)
Hardware is ok (if I boot with ayurfan distro I can see the external RTC module).
Could it be a kernel configuration problem? Has anyone had similar experience?
My Linux distro is Arch Linux Arm.
Regards
Max
if anyone would be interested I managed to make it all work.
- i've modified, recompiled and overwrite to original one (in /boot/dtb) rk3328-rock64.dts, adding this fragment of code
  &i2c0 {
      status = "okay";
      ds1307: ds1307@68 {
        compatible = "maxim,ds1307";
        reg = <0x68>;
        status = "okay";
      ds3231: ds3231@68 {
        compatible = "maxim,ds3231";
        reg = <0x68>;
        status = "okay";
to enable i2c0 bus and to let automatically discovered the rtc device by the kernel at boot time.
- blacklisted rock64 rtc module (rtc_rk808)
- added rtc_ds1307 module to automatic module loading system
After reboot rtc device will be created and the rtc module enabled
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 137 03-24-2024, 01:07 PM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,278 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,724 06-02-2023, 07:52 AM
Last Post: diederik
  Looking for guidance on setting up with external RTC Ditchmagnet 0 862 05-13-2022, 05:22 PM
Last Post: Ditchmagnet
  Linux 5.15 Kernel - openSuse mark1250 0 1,279 12-02-2021, 04:36 PM
Last Post: mark1250
  Alpine Linux isndw 12 17,771 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,351 07-29-2021, 07:19 AM
Last Post: shivarj89
Information Linux Mainline ayufan 63 91,987 05-14-2021, 10:41 AM
Last Post: Wizzard
  External hard drive problem k8Va 17 22,498 03-09-2021, 02:31 PM
Last Post: calinb
