Problem with time in rock64
Hi, I have ubuntu Bionic 18.04 installed and I have correctly chosen the time zone but it gives me one more hour.
I try with ntp, with sudo date, but I do not change the time to the right.
What can I do to fix the problem?
(11-10-2018, 10:20 AM)gedas07 Wrote: Hi, I have ubuntu Bionic 18.04 installed and I have correctly chosen the time zone but it gives me one more hour.
Open a terminal and run:
dpkg-reconfigure tzdata
and make sure 100% sure the system has the timezone set properly.
NTP etc will only update the system with UTC, no TZ info is set etc
Also make sure you have the most current tzdata package with the most up to date TZ config
I do this
https://feeding.cloud.geek.nz/posts/time...d-systemd/
And don't works , but i leave this for a one day and now the time is correct. I don know
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 150 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,353 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 334 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 608 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,359 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,413 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  Disabling last mount time check on boot acwest 0 623 03-03-2023, 09:24 PM
Last Post: acwest
