Wifi doesn't work after update
Every time (during the last months) since kernel image 6.1 appeared when I try to update the system from Debian 11 to 12 (Mobian) I can't find wifi adapter and I have to go back to my backup version where everything works. How much time will it take additionally? What do I do wrong? Is there anyone having the same problem?
The firmware for the wifi card is now in non-free-firmware (it was in non-free before). Hence you need to append "non-free-firmware" to the lines reflecting bookworm in /etc/apt/sources.list
(04-14-2023, 06:28 AM)jsch Wrote: The firmware for the wifi card is now in non-free-firmware (it was in non-free before). Hence you need to append "non-free-firmware" to the lines reflecting bookworm in /etc/apt/sources.list
Thank you, it works now.
  The program doesn`t detect the camera blag0rag 2 334 02-15-2024, 08:03 PM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,135 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 1,934 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,902 07-18-2023, 08:54 AM
Last Post: junelung
  how to update mobian over tor vusra 13 6,939 07-09-2023, 08:57 PM
Last Post: vusra
  PinePhone won't boot after software update jb2000 2 1,342 03-17-2023, 07:26 AM
  Most recent Mobian image or installer image known to work? DrPlamsa 13 4,964 02-26-2023, 11:47 PM
Last Post: SukiiPooru
Exclamation Impossible to login since the latest update anonymous 12 4,237 02-26-2023, 01:01 PM
Last Post: anonymous
  Recent install, no wifi user641 3 1,482 01-12-2023, 03:06 PM
Last Post: user641
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,334 11-28-2022, 03:30 PM
