Recent install, no wifi
Hello, just installed mobian with installer on my phone. Everything is working fine except for the wifi, it simply will not connect to my wifi, while other devices connect nromally, what can I do?
Do you have 2.4GHz wifi? Typically most people do but I know some who only have 5GHz. (The Pinephone does not support 5Ghz.)
(01-11-2023, 06:02 AM)Zebulon Walton Wrote: Do you have 2.4GHz wifi? Typically most people do but I know some who only have 5GHz. (The Pinephone does not support 5Ghz.)
Yes, it's 2.4 I know 5.0 won'twork...I am a daily driver pinephoner for almost 2 years, never had this problem before...
It's something related to my router's firmware, I am running openWRT, with another router it works fine.
  Phoch Trixie weekly install seems nice reTestability 0 190 03-10-2024, 08:47 AM
Last Post: reTestability
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  apt trying to install a package version not in the repo chainingsolid 1 487 11-12-2023, 03:54 AM
Last Post: evilbunny
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,888 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,227 04-14-2023, 10:07 AM
Last Post: nickolas
  Most recent Mobian image or installer image known to work? DrPlamsa 13 4,925 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  Wifi issue since last update and held back updates goku499 11 5,312 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,860 09-11-2022, 09:24 PM
  snap install exceeded maximum runtime jojuma 0 781 07-17-2022, 07:52 AM
Last Post: jojuma
  Problem with wifi kubussz 0 874 04-02-2022, 12:57 PM
Last Post: kubussz
