The program doesn`t detect the camera
Hello, I have a Pinephone with Mobian. Although megapixel works in it, no other program tells me the camera. I have tried "Camera", "Authenticator" or "Decoder", and I can't get it. Could someone help me get them to work?
Thanks a lot
Hello
Do you use Mobian Bookwork or Trixie?
The last time I tried to use Jitsi Meet online, it didn't work and it seemed that there were no easy solutions.
If your kernel is reasonably recent, applications that work with libcamera should work (sorta… the video will likely end up rotated, but at least you get video), assuming libcamera is installed to begin with. But many applications still do not work properly with the libcamera stack (e.g., because they use v4l2 directly, or they use GStreamer but hardcode the v4l2 source there). Those that use the highest-level abstraction (Pipewire) should just work, but that is a very new API, so not many applications are ported to it yet. GStreamer applications may or may not work depending on what assumptions they make.
But if you use an ancient kernel like the Mobian stable (bookworm) one, chances are libcamera will not work at all.
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,135 09-05-2023, 11:16 AM
Last Post: nickolas
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,210 07-17-2023, 01:49 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,234 04-14-2023, 10:07 AM
Last Post: nickolas
Exclamation The webcam doesn't work in Firefox anonymous 0 737 11-06-2022, 01:45 PM
Last Post: anonymous
  Megapixels doesn't work Glenn 4 2,786 08-28-2022, 03:19 PM
Last Post: vortex
  PP Keyboard doesn't charge Pinephone (Mobian) jojuma 1 1,234 08-06-2022, 01:10 AM
Last Post: elode
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 1,983 07-10-2022, 03:16 AM
Last Post: arkadione
  Trying the camera switch on my PinePhone gilwood 5 3,366 04-02-2022, 12:54 PM
Last Post: jhasler
  Change default program for a file type 3x5co 1 1,764 09-01-2021, 05:26 PM
  mobian, pinephone camera, and megapixels dawg161 32 29,418 05-01-2021, 02:34 PM
Last Post: NormandC
