Change default program for a file type
I installed VLC, and I use this for audio. When I use portfolio, the file manager, to open an audio file, it opens in Totem.
I don't want Totem at all, but if I try to remove it, it tries to totally remove Phosh.
Therefore, I need a way to change the default for audio files, to VLC. How do I do it?
Settings/Default Applications/Music
-or-
Attach a mouse or remote into the desktop with wayvnc, use the Mobian "Files" file manager instead of Portfolio, right-click on an audio file, select "Open With", then "Other Application", select application, select "Set as Default" on the lower right. (Right clicking on the file doesn't seem to work in Portfolio.)
  The program doesn`t detect the camera blag0rag 2 332 02-15-2024, 08:03 PM
  4G data on default startup / boot dcinoz 1 842 04-29-2023, 11:24 PM
Last Post: dcinoz
  Bogus default gateway keeps appearing Zebulon Walton 7 2,218 02-25-2023, 09:48 PM
  low disk space on file system root revisited benedikt55 2 1,508 09-24-2022, 10:16 AM
Last Post: benedikt55
  Change GUI from Phost to Gnome (or anything else) johnpine 0 853 05-27-2022, 06:52 AM
Last Post: johnpine
  User login change usagi 11 5,698 05-13-2022, 01:16 AM
Last Post: johnpine
  This Qutebrowser config file made browsing on the PinePhone great again ryo 0 1,225 01-05-2022, 05:49 PM
Last Post: ryo
  can't get file transfer working. Help, please! quixote 26 18,777 11-14-2021, 10:50 PM
Last Post: quixote
  File Transfer With Bluetooth food 0 1,063 10-29-2021, 11:00 AM
Last Post: food
  Installing Mobian --> "Resizing file system" forever Anna 13 12,925 09-09-2021, 04:26 AM
Last Post: spaetz
