low disk space on file system root revisited
I've flashed Mobian to the emmc and ran into the "low disk space on file system root"- issue. I already have removed unnecessary software, emptied tradh etc.......
I know this is still or has been a question discussed on this forum.
But there seem to be differentt ways of a solution.
Which one would you recommend?
Or is it depending of the chosen image?
(09-21-2022, 05:48 AM)benedikt55 Wrote: I've flashed Mobian to the emmc and ran into the "low disk space on file system root"- issue. I already have removed unnecessary software, emptied tradh etc.......
most likely, automatic resize did not work. i had this problem in recent weeks.
i hope you have ext4 fs and linux knowledge.
https://wiki.mobian.org/doku.php?id=trou...-pinephone
tried it, till an "........overlapping partitions" issue was arising..........what to do?
  Errors when start the system kubussz 2 580 11-21-2023, 11:07 AM
Last Post: kubussz
  System won't suspend due to suspention notification user641 6 1,446 09-24-2023, 05:47 AM
Last Post: user641
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,209 03-01-2023, 04:45 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,038 02-13-2023, 02:11 AM
Last Post: sharase
  Bluetooth audio revisited 3x5co 1 1,083 01-10-2023, 05:51 PM
  German Emergency Alarm System Test arno_nuehm 4 1,878 12-11-2022, 01:44 PM
Last Post: traut
  Low Disk Space on Filesystem root ichbins 9 4,192 08-28-2022, 10:52 AM
Last Post: Eugo
  Does mobian use a root account and password? rp3 6 7,787 04-04-2022, 07:26 PM
Last Post: parry
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 3,329 03-01-2022, 10:06 AM
Last Post: bujiraso
  This Qutebrowser config file made browsing on the PinePhone great again ryo 0 1,226 01-05-2022, 05:49 PM
Last Post: ryo
