4G data on default startup / boot
I recently turned my Pinephone back on with a SIM inserted - it had been last used in 4G mode only for VoLTE test purposes with mobile data off.
This time mobile data was on - I had to disable the still incorrect aeroplane mode - this turned on bluetooth - and I could then access the mobile data setting to turn it off.
I ran updates and rebooted and the same thing happened, the phone restarted with 4G data back on whereas data had been turned off before restarting it.
How come this has changed? How do I disable data at startup? Why are the settings prior to restart / reboot not preserved?
Can't believe the aeroplane mode bug is still present too....
I could find nothing on https://salsa.debian.org/groups/Mobian-team/-/issues
or https://source.puri.sm/Librem5/phosh/-/issues
Curious as to whether or not anyone else has noticed this.
Thanks for your help / feedback.
Deleting all mobile related files in /etc/NetworkManager/system-connections/ has fixed it.
Mobile data is no longer enabled at boot.
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,018 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 951 09-29-2023, 11:29 PM
  gnome-control-center: segmentation fault on startup jojuma 4 1,101 09-12-2023, 08:49 AM
Last Post: jojuma
  Mobian boot failed with zstd message after upgrade. Mahgue 0 641 09-01-2023, 11:29 AM
Last Post: Mahgue
  Is that a Multiboot selection on startup? jojuma 0 510 07-09-2023, 03:09 AM
Last Post: jojuma
  PinePhone won't boot after software update jb2000 2 1,343 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 970 03-06-2023, 12:06 PM
Last Post: freelectro
  Bogus default gateway keeps appearing Zebulon Walton 7 2,218 02-25-2023, 09:48 PM
  boot gets stuck shortly after disk decryption vortex 8 4,034 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
