gnome-control-center: segmentation fault on startup
Since an update within the last three days, I can't open the Settings app (gnome-control-center) any more.
It quits returning a segmentation fault. I reinstalled gnome-control-center,itself and the packages it depends on.
Still segmentation fault on startup.
Is there anything I can do about that but reinstalling the whole OS?
I had that problem already some time ago and I could only help myself by setting up the whole system again. I'd like to avoid that...
Thanks!
(09-11-2023, 02:05 AM)jojuma Wrote: Since an update within the last three days, I can't open the Settings app (gnome-control-center) any more.
Thanks!
It works again after I installed today's updates.
Thanks!
My system is up to date already. Just checked again. The problem consists...
try `gsettings reset org.gnome.Settings last-panel`
(09-11-2023, 11:31 AM)jsch Wrote: try `gsettings reset org.gnome.Settings last-panel`
Command executed successfully but I still get a segmentation fault on startup.
I tried everything I found across the web.
Of course debugging is an option, but from what I see flashing the system is less effort...
So I back up my data now and set up the system again...
  No volume control after latest updates Zebulon Walton 19 7,195 09-08-2023, 08:28 AM
Last Post: jessencan
  Is that a Multiboot selection on startup? jojuma 0 510 07-09-2023, 03:09 AM
Last Post: jojuma
  4G data on default startup / boot dcinoz 1 845 04-29-2023, 11:24 PM
Last Post: dcinoz
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,076 09-30-2022, 08:53 PM
Last Post: treebeard
  Gnome Web CSS problem? jojuma 0 822 05-27-2022, 11:43 AM
Last Post: jojuma
  Change GUI from Phost to Gnome (or anything else) johnpine 0 853 05-27-2022, 06:52 AM
Last Post: johnpine
  Gnome-podcasts on Debian repos user641 4 3,004 02-06-2022, 04:58 AM
Last Post: jsch
  Gnome podcasts user641 0 883 01-03-2022, 06:56 PM
Last Post: user641
  Gnome podcasts user641 4 3,235 11-08-2021, 05:50 AM
Last Post: user641
  Chatty, SMS does not work - could hardware be at fault? AntonReiser 36 25,316 11-02-2021, 03:42 AM
Last Post: AntonReiser
