Gnome podcasts
Will it be soon possible to install gnome-podcasts on mobian as a .deb package? I don't like using flatpaks.
I learned I had 2 Flatpaks installed after realizing that my eMMC was almost full, the Flatpak folder alone singlehandedly filled up the entire storage with basically garbage data.
Those were the only 2 I installed from "Software Center" rather than apt, so I agree when you say you don't like using Flatpaks.
As for gnome-podcasts, you can alternatively install Git, Meson, Gstreamer, Rust, and Cargo, and then do the following:
git clone https://gitlab.gnome.org/World/podcasts.git gp
cd gp
meson --prefix=/usr build
ninja -C build
sudo ninja -C build install
母語は日本語ですが、英語も喋れます(ry
(11-07-2021, 09:26 PM)ryo Wrote: I learned I had 2 Flatpaks installed after realizing that my eMMC was almost full, the Flatpak folder alone singlehandedly filled up the entire storage with basically garbage data.
cd gp
ninja -C build
Thanks for the help, but after the command :
I get "command not found", what am I doing wrong? I installed git and meson before
cd gp
ninja -C build
Did you install Meson through Pip or Apt?
Other than for making a some modifications in Phosh, I never really used Meson myself, so I can't really assist on that one.
cd gp
ninja -C build
Through apt, np thanks anyway for the intention to help. "arigato"
  gnome-control-center: segmentation fault on startup jojuma 4 1,116 09-12-2023, 08:49 AM
Last Post: jojuma
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,082 09-30-2022, 08:53 PM
Last Post: treebeard
  Gnome Web CSS problem? jojuma 0 824 05-27-2022, 11:43 AM
Last Post: jojuma
  Change GUI from Phost to Gnome (or anything else) johnpine 0 853 05-27-2022, 06:52 AM
Last Post: johnpine
  Gnome-podcasts on Debian repos user641 4 3,006 02-06-2022, 04:58 AM
Last Post: jsch
  Gnome podcasts user641 0 887 01-03-2022, 06:56 PM
Last Post: user641
  *urgent help*calls and gnome-conatcs gone after update user641 24 17,735 09-20-2021, 12:19 PM
Last Post: calinb
  gnome podcasts on debian repo, dino-mobile user641 3 3,261 09-11-2021, 12:04 AM
Last Post: user641
  (Gnome) Maps won't start on Mobian? TRS-80 3 3,227 07-11-2021, 12:09 PM
Last Post: TRS-80
  Is there a way to do gnome-authenticator via the command line? motox6 0 1,217 05-06-2021, 10:41 PM
Last Post: motox6
