gnome podcasts on debian repo, dino-mobile
Hello is there something in progress to put gnome podcasts or other podcast client in the debian repository? I am not a big fan of platpak.
Also having dino-mobile in the debian repo like the manjaro phosh distro would be amazing.
(09-09-2021, 09:45 AM)user641 Wrote: Hello is there something in progress to put gnome podcasts or other podcast client in the debian repository? I am not a big fan of platpak.
I've not heard of anything. I think Gnome is a big fan of flatpaks so they will continue to use it. In theory someone could for the project and make a deb file then submit that but that would probably be pretty annoying to do. Or you could open an issue on their Gitlab page and ask about it!
I compiled dino-mobile directly on my phone, it wasn't too hard. Find my post in the issue at Dino's GitHub, I left a comment about a couple missing packages I ended up needing to install.
Cheers,
TRS-80
Protocols, not Platforms
(09-10-2021, 07:50 PM)TRS-80 Wrote: I compiled dino-mobile directly on my phone, it wasn't too hard.  Find my post in the issue at Dino's GitHub, I left a comment about a couple missing packages I ended up needing to install.
I will look into it, thanks!
  Mobile internet via cellular network mostly not working Anna 18 10,335 01-19-2024, 02:59 AM
Last Post: anonymous
  apt trying to install a package version not in the repo chainingsolid 1 503 11-12-2023, 03:54 AM
Last Post: evilbunny
  gnome-control-center: segmentation fault on startup jojuma 4 1,114 09-12-2023, 08:49 AM
Last Post: jojuma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,468 08-31-2023, 12:38 PM
Last Post: vusra
  Debian bookworm security repo user641 2 1,586 02-17-2023, 01:12 AM
Last Post: user641
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,582 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,387 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,558 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 17,051 10-29-2022, 09:16 AM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,081 09-30-2022, 08:53 PM
