Change GUI from Phost to Gnome (or anything else)
Hello Community,
I'm running mobian-installer-pinephone-phosh-20220327 and it's working great except the GUI Phosh is driving me crazy - one in every three times I want to press spacebar it pulls up the app overview making me want to throw the phone towards the floor...
I wanted to try the original Gnome as recommended here but I ran into unmet dependencies problem:
# apt install gdm3
Reading package lists... Done
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libmutter-10-0 : Breaks: libgtk-3-0 (< 3.24.33-2~) but 3.24.33-1mobian1 is to be installed
E: Unable to correct problems, you have held broken packages.
Does anybody know how to fix it? Or which GUI are you guys running on top of Mobian? I'm willing to try anything as long as it does not have spacebar and "show apps" next to each other within 2milimeters on the screen...
Thank you in advance
  gnome-control-center: segmentation fault on startup jojuma 4 1,099 09-12-2023, 08:49 AM
Last Post: jojuma
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,073 09-30-2022, 08:53 PM
Last Post: treebeard
  Gnome Web CSS problem? jojuma 0 821 05-27-2022, 11:43 AM
Last Post: jojuma
  User login change usagi 11 5,694 05-13-2022, 01:16 AM
Last Post: johnpine
  Gnome-podcasts on Debian repos user641 4 3,002 02-06-2022, 04:58 AM
Last Post: jsch
  Gnome podcasts user641 0 883 01-03-2022, 06:56 PM
Last Post: user641
  Gnome podcasts user641 4 3,234 11-08-2021, 05:50 AM
Last Post: user641
  *urgent help*calls and gnome-conatcs gone after update user641 24 17,704 09-20-2021, 12:19 PM
Last Post: calinb
  gnome podcasts on debian repo, dino-mobile user641 3 3,253 09-11-2021, 12:04 AM
Last Post: user641
  Change default program for a file type 3x5co 1 1,763 09-01-2021, 05:26 PM
