The latest update of eg25-manager seems to cause frequent disconnections
Exclamation
Hello
I updated Mobian Linux about 2 hours ago and now, I lose the network every ten minutes Sad I don't use the power saving mode right now. Be very careful when updating. If anybody has a suggestion, let me know.
In network settings, you could uncheck connect automatically for all networks.
Save settings and connect manually.
(11-07-2022, 12:35 PM)anonymous Wrote: I updated Mobian Linux about 2 hours ago and now, I lose the network every ten minutes Sad I don't use the power saving mode right now. Be very careful when updating. If anybody has a suggestion, let me know.
Thats wierd because v4.6 fixes the udev rules messed-up by 4.5.  What are your results from running...
grep -r . /sys/devices/platform/soc/1c1b000.usb/usb2/2-1/power/{control,autosuspend_delay_ms,wakeup,persist}
Did you reboot after the upgrade? Are you using the stock firmware?  Pinephone or Pinephone Pro?
I went back to the September 25th image... it still drops occasionally but doesn't seem nearly as bad
I use a Pinephone, not a Pinephone Pro. I use the stock firmware for now. I rebooted three times after upgrading. Now, I lose the connection less often but it's still problematic. I lost the connection during the night which means nobody could call me in case of emergency. I'm going to try your suggestion as soon as possible.
(11-07-2022, 12:35 PM)anonymous Wrote: Be very careful when updating.
Thank you very much for the warning!! (Just in time...!)
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
I do an image backup of the eMMC every few weeks in order to recover if an update goes horribly wrong. I also keep an outdated but known-to-work SD card on hand to use if needed.
I've been having trouble since around the same update / upgrade and finally, dist-upgrade. I tried downgrading to the previous eg25-manager to no avail.
Bug report submitted:
https://gitlab.com/mobian1/issues/-/issues/476
(11-11-2022, 04:37 PM)calinb Wrote: I've been having trouble since around the same update / upgrade and finally, dist-upgrade. I tried downgrading to the previous eg25-manager to no avail.
That gitlab is being shutdown in favor of https://salsa.debian.org/Mobian-team .  However eg25-manager is now a debian thing instead of a mobian thing so bugs would need to be reported using the reportbug tool or via email anyway.
I use Ting (a T-mobile MVNO) on my test phone and found that sometime in the last several weeks T-Mobile apparently dropped IPv4 and it caused me problems that sound similar to yours.  See https://forum.pine64.org/showthread.php?tid=17552
Maybe your DNS is returning IPv4 addresses even though you have no valid route?
Edit 1: though maybe the fact that your wife's phone still works points a finger in a different direction.
I could not logon to the new salsa site, though it said I could logon w/ a gitlab logon, so I had no other way to attempt to report the bug.
Thanks for your post/!
  No volume control after latest updates Zebulon Walton 19 7,181 09-08-2023, 08:28 AM
Last Post: jessencan
  how to update mobian over tor vusra 13 6,936 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,234 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,341 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 4,237 02-26-2023, 01:01 PM
Last Post: anonymous
  need help with downgradin network-manager Ferriah 0 643 11-07-2022, 04:51 PM
Last Post: Ferriah
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,847 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,675 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,328 09-21-2022, 02:39 PM
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,864 09-11-2022, 09:24 PM
