How to import contacts into the phone book app?
I have the Manjaro Beta Edition. I'm trying to import my contacts into the phone book. I can tell it to import, I can navigate to a csv file of contacts, and I think I select the file, but then nothing happens and there are still no contacts.
What format does it want, and any idea what I'm doing wrong?
(06-02-2021, 09:22 PM)nelstomlinson Wrote: What format does it want, and any idea what I'm doing wrong?
You are doing it right, but use the vcf format instead.
acrux, there must be more to it than that. I'm now trying to import a vcf file, and same results: I select the file, then nothing.
(06-03-2021, 07:13 PM)nelstomlinson Wrote: acrux, there must be more to it than that. I'm now trying to import a vcf file, and same results: I select the file, then nothing.
Hmm, I have imported a vcf file several times without a problem... If the file has correct format then I'm out of ideas...
Oops, correct format was the sticking point. I fixed the format issue, caused by my careless editing, and all is well. Thanks! It would be nice if the program popped up an error message, even something relatively uninformative like import failed or so would help.
Hi, I'm on the latest manjaro-arm with Phosh. I don't find any options to import contacts with gnome-contacts. Can you please provide more specifics about what program you were using and/or how to find the option to import from vcf?
Eric
(07-02-2021, 10:55 PM)worden Wrote: Hi, I'm on the latest manjaro-arm with Phosh. I don't find any options to import contacts with gnome-contacts. Can you please provide more specifics about what program you were using and/or how to find the option to import from vcf?
Eric
Eric, I was using whatever program handles contacts under Manjaro Plasma. It shows up simply as Phonebook, and the only option it has is Import Contacts.
Eric
Hi. You can install Evolution and use scale-to-fit. It has a contact import option in one of the menus. Maybe someone knows a simpler option?
Eric
I really hope the possibility to Export/Import contacts, will be avable in a new version of Gnome Contacts.
I do a search, I find this : https://forum.pine64.org/showthread.php?tid=14279
  New phone, KDE desktop settings reset on reboot zzb0 2 1,770 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 563 09-24-2023, 05:18 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,520 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  How do I import SIM card contacts? Logological 8 5,350 06-04-2023, 12:49 PM
Last Post: mruser1
  New issue with phone calls kmsgli 13 6,731 08-15-2022, 01:45 PM
Last Post: Gon
  Phone goes to sleep whilst audio playing new2pinephone 0 1,349 12-22-2021, 05:50 PM
Last Post: new2pinephone
  After fresh install outbound phone calls not working. tckosvic 2 2,370 11-10-2021, 10:45 AM
Last Post: tckosvic
Music Can only hear/speak during a phone call when on speakerphone danimations 4 3,486 10-24-2021, 11:47 PM
Last Post: danimations
  Installed Sim phone not working kmk7x 3 2,708 10-24-2021, 11:43 PM
Last Post: bcnaz
  nextcloud contacts are duplicating Uturn 1 1,853 10-24-2021, 01:35 AM
Last Post: user641
