Installed Sim phone not working
Modem status does not show carrier
Network - Unknown
Signal - 41%
Network Status Not registered
Own Number - ***-***-****  Is Correct
Is there a patch or anything to get this modem to work correctly?  Still new and learning everyday.
Thanks,
kmk
More info needed - which carrier in which country, and does their local cell use frequencies supported by the PinePhone?
(10-24-2021, 03:56 AM)wibble Wrote: More info needed - which carrier in which country, and does their local cell use frequencies supported by the PinePhone?
Hey Brother,
United States, T-mobile.  yes supported too.
Kmk
1) is your O.S. updated ?
2) with the Pinephone, it is quite simple to flash and run an micro-sd card, quick way to see if the 'installed' O.S. is faulty.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  New phone, KDE desktop settings reset on reboot zzb0 2 1,763 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 558 09-24-2023, 05:18 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,514 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  New issue with phone calls kmsgli 13 6,719 08-15-2022, 01:45 PM
Last Post: Gon
  Keyboard case stopped working on pacman update rotwang 5 3,175 05-07-2022, 09:17 PM
Last Post: rotwang
  Calls & SMS stopped working Schugy 3 2,402 12-28-2021, 05:00 AM
Last Post: Schugy
  Phone goes to sleep whilst audio playing new2pinephone 0 1,345 12-22-2021, 05:50 PM
Last Post: new2pinephone
  No incoming SMS. Outgoing SMS, calls and data working. HardwarePunk 3 3,077 11-20-2021, 12:53 AM
Last Post: HardwarePunk
  Why is sshd installed/listening by default insidetrip101 0 1,172 11-14-2021, 10:29 AM
Last Post: insidetrip101
  Ctrl-O on virtual keyboard not working in nano PJK2012 3 3,180 11-11-2021, 08:47 PM
Last Post: PJK2012
