nextcloud contacts are duplicating
with KDE plasma mobile, i happened to add the same nextcloud account twice. So, my address book showed every contact twice. Now I deleted one of these identical nextcloud accounts. The duplicated contacts remained. Next I deleted my other nextcloud account.
Zero account left, but all contacts remained twice in phone book app. After a restart, I added my Nextcloud accoung again: Now I have three copies of each contact.
Sync with nextcloud does not seem to work as it should.
How can I clear the local contacts data so phone book is empty again?
So I could set my cloud syncing from scratch?
Is it maybe better to set up vdirsyncer for cloud syncing?
(10-20-2021, 08:35 AM)Uturn Wrote: with KDE plasma mobile, i happened to add the same nextcloud account twice. So, my address book showed every contact twice. Now I deleted one of these identical nextcloud accounts. The duplicated contacts remained. Next I deleted my other nextcloud account.
Maybe the easiest way is to delete the contacs file in .local .config and .cache, you can delete also the folder os nextcloud there and setup everything again.
  CardDAV / Nextcloud sync broken Uturn 0 695 06-15-2023, 12:41 AM
Last Post: Uturn
  How do I import SIM card contacts? Logological 8 5,351 06-04-2023, 12:49 PM
Last Post: mruser1
  .CSV Without Nextcloud food 5 2,007 01-24-2023, 03:51 PM
Last Post: alaraajavamma
  nextcloud setup mruser1 2 1,722 12-05-2022, 03:22 AM
  how to connect calindori to nextcloud? Uturn 2 2,327 06-26-2022, 02:09 AM
Last Post: wibble
  Nextcloud folder (WebDAV) not showing up in Portfolio PinePhoneUser 1 1,427 01-13-2022, 08:31 AM
Last Post: Uturn
Question Backing up contacts prior to OS reinstall danimations 3 2,521 09-27-2021, 03:35 AM
Last Post: kqlnut
  How to import contacts into the phone book app? nelstomlinson 8 6,899 07-18-2021, 03:26 AM
Last Post: Gary2003
  Contacts not Importing mdshell 1 2,217 03-30-2021, 02:24 AM
Last Post: acrux
  Plasma Mobile, Nextcloud account Uturn 1 2,162 03-05-2021, 09:14 AM
Last Post: Veraendert
