pinebook pro tools
#51
I think I responded elsewhere. I also found that only mpeg2video was working via vaapi. they folks that worked on rockchip/vaapi abandoned afterwards.
whatever work you put into this it should be AFTER applying the libreelec/kwiboo rockchip and ffmpeg patches.
i need to sync up with current development. I've happily been using 5.8 with full hwaccel on kodi, which met my needs. I hope to sync up soon.
(04-03-2021, 04:13 PM)xmixahlx Wrote: I think I responded elsewhere. I also found that only mpeg2video was working via vaapi. they folks that worked on rockchip/vaapi abandoned afterwards.
Thanks for the update @xmixahlx  !  Just to be clear, the libreelec/kwiboo patches are the ones from the resources tree in the pbp-tools repo, correct?  I've gotten confused with the myriad repositories available for ffmpeg but have only applied the kernel patches from pbp-tools (which I updated for 5.10.17).
Anyway, it seems I'm at the same point you seem to be.  I think telling the user-space devs here that DRM for HW accelleration is the best approach for now.
My tests so far show:
Quad stream, single thread test with -re option uses 100% of a single core. Best results are using yuv 4:2:0 which is close to 30FPS with varied scalings. 1080p on all streams is only about 15-20 FPS. 720p on all streams is about 18-25 FPS. Incrementing the thread count by 1 with ffmpeg will improve this slightly but does not reach 30 FPS for 1080p, though 720p approaches it.
For anyone still interested in testing this I found the nVidia coded documentation helpful in finding test scenarios with ffmpeg.
Michael J. Hammel
mjhammel@graphics-muse.org
michaelhammel@acm.org
  Debian on Pinebook Pro u974615 7 1,290 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,812 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,230 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,322 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,835 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,328 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,472 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,546 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,654 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 683 07-13-2023, 05:21 PM
Last Post: owaspfap
