Manjaro w/ Panfrost Drivers vs stock Debian Video Performance
I was just wondering how the video performance i.e. YouTube, Netflix, playing video files, games, etc. compares between Manjaro with Panfrost drivers and stock Debian. Also if anyone has played supertuxkart on the PBP, what graphics settings and FPS can I expect.
Thank you!
supertuxkart requires OpenGL ES 3.0, so I think you need a Kernel > 5.3 and mesa-git and also set the environment variable PAN_MESA_DEBUG=gles3
Netflix is also not a current possibility for any kind of benchmarking on Manjaro. There is no aarch64 Widevine available to be able to watch it.
you can run supertuxkart with gles2 in a low graphics mode. using gles3 it can support graphics quaility 2. I was getting 60fps in testing.
vaapi for wayland just landed in firefox nightly, and hantro/rkvdec are improving in kernel 5.7.
ask the question again in may Wink.
(03-02-2020, 08:10 AM)tophneal Wrote: Netflix is also not a current possibility for any kind of benchmarking on Manjaro. There is no aarch64 Widevine available to be able to watch it.
Will Netflix work via a Kodi?
As there is currently no Kodi which works on PBPro i guess Netflix will also not work.
Even if there were a Kodi available to use, likely not, since Netflix requires Widevine. Without an aarch64 Widevine, no Netflix at all.
I thought it was possible to extract widevine from chromium os builds
32bit aka armhf only at present
kodi works fine on pbp, including 18.6 just released.
(03-02-2020, 08:06 AM)maxjrh Wrote: supertuxkart requires OpenGL ES 3.0, so I think you need a Kernel > 5.3 and mesa-git and also set the environment variable PAN_MESA_DEBUG=gles3
Setting the environment variable breaks the game. The graphics don't render. I am running Manjaro with Panfrost drivers.
  Official Debian support moonwalkers 63 52,987 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,451 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 360 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 396 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,835 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 400 01-19-2024, 11:32 PM
  Streaming video sites tessa 1 1,107 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,296 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,403 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 472 12-07-2023, 03:11 PM
