Using DD to Backup and Restore EMMC
(02-01-2020, 01:38 PM)appdev46 Wrote: I re-installed the default Debian image and re-tried the whole process again.  For some reason it worked correctly the second time!
I wish this process was faster though...
At least I can make a backup now and restore when I break things.
Somehow I missed this thread before I started one about the same thing. Though after I dd my image I took it to a different pc to flash that image to another sdcard using balena etcher just to test if my back up worked by booting it off sdcard. Doing it that way had not been successful. I'm nervous to try what you did incase it didn't work. Would it be better to just have my sdcard already bootable with the stock image from the Wiki then just dd my image to that sdcard?
Using DD to Backup and Restore EMMC - by appdev46 - 01-31-2020, 04:08 PM
RE: Using DD to Backup and Restore EMMC - by FeMike - 02-05-2020, 04:31 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,233 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 451 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,022 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,566 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,959 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 882 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,133 10-10-2022, 06:22 AM
Last Post: maxjrh
  6/22 run of PBPs - is reimaging eMMC with new OS possible still? elitegamercody 29 11,888 10-04-2022, 07:55 PM
  Debian emmc installer db579 6 3,076 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,530 08-18-2022, 11:26 PM
Last Post: calinb
