newer ""emmc-installer" images (manjaro xfce)
The latest seems to be 20.04 is there any newer version?
Thanks.
The newest Manjaro version is 22.08. You can use the generic image for the PinebookPro.
Check out the release announcement:
https://forum.manjaro.org/t/manjaro-arm-...sed/119602
You might want to ask Manjaro specific questions in the Manjaro ARM forum.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,712 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,561 07-04-2025, 07:46 AM
Last Post: remph
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,428 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,527 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,215 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,750 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,097 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,430 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,671 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,562 12-07-2023, 03:11 PM
