Can't boot new 0.6.41
(05-24-2018, 10:01 AM)edupv Wrote: I was using bionic-minimal-rock64-0.6.33-211-arm64.img.xz, I upgraded to the current stable release 0.6.41-227 by "apt upgrade" today, then my rock64 is unable to boot now. I don't have a working usb serial console adapter, so I don't know the boot message.
I am using an emmc module, I tried the "jumper pull" method (pull emmc jumper 2-3 seconds after applying power) many times to boot the sdcard, but have never succeed. I can boot the sdcard (armbian) only when the emmc module removed from the socket. I don't know how to make my rock64 working with the emmc module again.
Try pulling the jumper a little sooner, nearer to 1-2 seconds, and then try a bit longer 3-4 seconds... I suspect it will be the former that will fix it not the latter... uboot could be nearly finished booting from the microSD before the eMMC is enabled. Otherwise, if you write the 0.6.44 image from ayufan to to your microSD, and boot from it with the jumper left connected, I'm wondering if that is the purpose of the new rock64_reset_emmc.sh script, so that you can reset it and then access it?
If that doesn't work, your best/simplest option may be to get a usb-to-eMMC adapter... then you can always just unplug the eMMC and write to it on another computer...
Can't boot new 0.6.41 - by Brendon - 05-23-2018, 02:37 PM
RE: Can't boot new 0.6.41 - by pfeerick - 05-23-2018, 09:54 PM
RE: Can't boot new 0.6.41 - by pfeerick - 05-24-2018, 05:58 AM
RE: Can't boot new 0.6.41 - by Luke - 05-24-2018, 06:17 AM
RE: Can't boot new 0.6.41 - by Brendon - 05-24-2018, 09:37 AM
RE: Can't boot new 0.6.41 - by Luke - 05-24-2018, 12:14 PM
RE: Can't boot new 0.6.41 - by edupv - 05-24-2018, 10:01 AM
RE: Can't boot new 0.6.41 - by pfeerick - 06-02-2018, 10:43 PM
  Rock64 won't boot dstallmo 0 377 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 630 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 662 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 7,909 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,076 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,633 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 2,143 12-20-2020, 02:24 PM
Last Post: Turbo
  Unable to boot armbian fchazal 2 3,919 05-19-2020, 06:43 PM
Last Post: Rocklobster
  Rock64s will not boot any OS camosoul 2 3,493 05-19-2020, 06:38 PM
  Help me understand the boot up process olivercfc 0 1,958 11-10-2019, 08:30 AM
Last Post: olivercfc
