Read-only problem
Space is not the issue, only 5GB in use ...
I'm now looking in to kern.log and find this from the last days before read-only-"crash"
Apr  1 20:37:12 MDserver64 kernel: [1038414.257579] EXT4-fs (mmcblk0p7): error count since last fsck: 4
Apr  1 20:37:12 MDserver64 kernel: [1038414.266661] EXT4-fs (mmcblk0p7): initial error at time 1520438366: ext4_journal_check_start:56
Apr  1 20:37:12 MDserver64 kernel: [1038414.275943] EXT4-fs (mmcblk0p7): last error at time 1520447884: ext4_remount:4710
Apr  2 20:38:59 MDserver64 kernel: [1124923.760669] EXT4-fs (mmcblk0p7): error count since last fsck: 4
Apr  2 20:38:59 MDserver64 kernel: [1124923.779625] EXT4-fs (mmcblk0p7): initial error at time 1520438366: ext4_journal_check_start:56
Apr  2 20:38:59 MDserver64 kernel: [1124923.798711] EXT4-fs (mmcblk0p7): last error at time 1520447884: ext4_remount:4710
Apr  3 07:34:54 MDserver64 kernel: [1164279.633485] mmcblk0: error -110 sending status command, retrying
Apr  3 07:34:54 MDserver64 kernel: [1164279.664787] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
Apr  3 07:34:54 MDserver64 kernel: [1164279.674269] mmcblk0: status not valid, retrying timeout
Apr  3 12:49:29 MDserver64 kernel: [1183155.075634] mmcblk0: error -110 sending status command, retrying
Apr  3 12:49:29 MDserver64 kernel: [1183155.101534] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x900
Apr  3 12:49:29 MDserver64 kernel: [1183155.120492] mmcblk0: status not valid, retrying timeout
Also here is the startup log (i'm not so good at it :p )
https://pastebin.com/VVdr2fC0
So this is also from today
Apr  4 17:54:50 MDserver64 kernel: [86809.605166] EXT4-fs (mmcblk0p7): error count since last fsck: 6
Apr  4 17:54:50 MDserver64 kernel: [86809.624101] EXT4-fs (mmcblk0p7): initial error at time 1520438366: ext4_journal_check_start:56
Apr  4 17:54:50 MDserver64 kernel: [86809.643169] EXT4-fs (mmcblk0p7): last error at time 1522763019: ext4_journal_check_start:56
Read-only problem - by mikedhoore - 04-03-2018, 12:14 PM
RE: Read-only problem - by xalius - 04-04-2018, 10:26 AM
RE: Read-only problem - by mikedhoore - 04-04-2018, 01:00 PM
RE: Read-only problem - by xalius - 04-04-2018, 03:14 PM
RE: Read-only problem - by mikedhoore - 04-04-2018, 11:53 PM
RE: Read-only problem - by zein - 07-14-2020, 11:41 AM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,494 10-12-2023, 05:14 PM
Last Post: tpaul
  External hard drive problem k8Va 17 22,652 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 2,997 08-17-2020, 10:35 AM
Last Post: max
Question bluetooth rock64 problem deta 3 5,078 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,187 01-20-2020, 12:25 PM
Last Post: kf5zmi
  ROCK64 Kernel compilation problem cao 0 2,484 01-21-2019, 01:21 AM
Last Post: cao
Lightbulb Wifi problem Nether494 13 17,597 11-28-2018, 01:48 PM
Last Post: Nether494
  Problem with time in rock64 gedas07 2 4,636 11-12-2018, 12:07 PM
Last Post: gedas07
  WiFi on Armbian problem scalextrix 14 17,924 09-08-2018, 01:13 AM
Last Post: scalextrix
  xrdp problem with Rock64 cenicero 2 3,609 08-07-2018, 12:42 PM
Last Post: cenicero
