xrdp problem with Rock64
i'm using a Rock64 with Xenial Mate (Ayufan), and after installing xrdp via apt (without problems), i try to connect to my Rock64 via RDP (using Remmina at other Linux machine or Rdesktop from a Windows laptop) and i get a login screen where i select XRDP or X11RDP, and after log in, just an empty blue screen. Nothing more, and amtpy desktop, without options, menus, etc...
What should i fix to make it work?
Thanks.
I suggest you upgrade to one of the newer images (running rdp on omv build without issues) https://github.com/ayufan-rock64/linux-build/releases
thanks for your reply. I have deleted my sd card and tried again the new versions you proppose (eactly bionic-lxde-rock64-0.7.9-1067-arm64.img.xz , 0.7.9, published 12 days ago), and it fails. I just "apt-get install xrdp", check it is running and then try to connect from a Windows machine with Remote Desktop to my Rock64 IP. It connects sucessfully, get a menu to choose the connection type (i try both, rdp and x11rdp) and after doing a sucessfull login, i get an empty and blu screen.
Am i doing it right? What can i do?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 149 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,353 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 333 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 611 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 606 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,356 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,342 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,304 12-07-2022, 08:22 PM
Last Post: luminosity7
