6/22 run of PBPs - is reimaging eMMC with new OS possible still?
#23
I just wanted to add that I've been flashing a LOT of images over the last few days on a brand new Pinebook Pro (the newer re-designed model, which also doesn't appear to have a functional eMMC-disable switch) and I've found that pretty much every image I flash using macOS will refuse to boot with flashing power light (kernel panic), with the sole exception of Armbian (which is much smaller than all the other images, which is what I imagine the difference is.)
However, booting into Armbian and flashing with `sudo dd if=/path/to/*.img of=/dev/mmcblk* bs=1M status=progress` has worked very consistently. Loading all of the WiFi firmware after the fact is a pain and the Debian install script requires a lot of modifications to work, but ultimately I've ended with an encrypted Debian installation on my eMMC with functional sleep and WiFi loading up with Tow-Boot.
RE: 6/22 run of PBPs - is reimaging eMMC with new OS possible still? - by steeb - 08-31-2022, 08:34 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,283 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 468 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,048 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,599 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 4,008 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 898 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,146 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 3,105 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,696 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,652 08-18-2022, 11:47 AM
Last Post: Bemo
