6/22 run of PBPs - is reimaging eMMC with new OS possible still?
Do either of you actually know that there was code in the SPI before you overwrote it? I suspect there was not. This is the way all PBPs up till this point have been. If I'm right, we need to ignore the kerfuffle about the PPP. It doesn't apply to the PBP.
Edit: I did find mine to be blank, as I expected.
:wq
[ SRA accepts you ]
RE: 6/22 run of PBPs - is reimaging eMMC with new OS possible still? - by KC9UDX - 08-27-2022, 03:07 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,284 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 468 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,048 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,599 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 4,008 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 898 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,146 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 3,106 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,697 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,652 08-18-2022, 11:47 AM
Last Post: Bemo
