6/22 run of PBPs - is reimaging eMMC with new OS possible still?
I was able to reimagine the eMMC with a Pinebook Pro Manjaro image but I only make it to the U-Boot screen. If I try to boot any Manjaro kernel my system enters a kernel panic.
I can drop to the U Boot console but I can’t access or determine the mount point of the SD card so I may install Tow-Boot to the SPI. Can someone just post a functioning Manjaro image so I can see if I may boot from that? I have the switch set away from the display in order to not prioritize eMMC booting but I can’t seem to boot from the SD card.
Is there any place Pine hosts the factory eMMC image, so I may just return my device to factory? My backup causes kernel panics so I am concerned the drive I flashed the backup image to is faulty and I no longer have a backup to use.
Everyone would appreciate the ability to reset the device.
Is the factory UBoot image on the SPI only able to boot the factory image? Is that some one-off checksum that is irretrievably lost if your backup gets corrupted?
RE: 6/22 run of PBPs - is reimaging eMMC with new OS possible still? - by elitegamercody - 08-25-2022, 06:08 AM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 458 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,030 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,575 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,965 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 887 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,136 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 3,078 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,547 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,631 08-18-2022, 11:47 AM
Last Post: Bemo
Users browsing this thread: 9 Guest(s)
