6/22 run of PBPs - is reimaging eMMC with new OS possible still?
Well no
Nearly every image will have a uboot package in 1st 16M, I have only seen 1 without
(and I have a uSD wallet with 24 sd cards in it... for pbp ... hard to keep track)
So manjaro on emmc has a not very good MAINLINE uboot , almost certainly
BSP uboots have 3 files, idbloader, uboot and trust, all .img
Mainline has 2, uboot and trust are merged, uboot is often uboot.itb or u-boot.itb
There is 1 other than towboot that can drive display, all other are serial comms only
All uboot does is search (&manage) storage, copy kernel, initrd and dtb to specific memory locations
and do serial comms
The dtb does the other 'bios' type configuration (and also manage storage, replacing uboot config)
Once kernel, initrd and dtb are loaded, uboot is done, releases its memory, exits
BTW, I just tested towboot again, still poor vis a vis sleep, ~5 d from my 1/2 d test
uboot (and towboot) have recently increased capability for usb carriers,,,, uSD or SD in usb dongle
RE: 6/22 run of PBPs - is reimaging eMMC with new OS possible still? - by wdt - 08-24-2022, 09:33 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,245 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 458 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,030 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,577 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,965 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 887 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,136 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 3,081 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,597 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,631 08-18-2022, 11:47 AM
Last Post: Bemo
