6/22 run of PBPs - is reimaging eMMC with new OS possible still?
(08-24-2022, 07:43 PM)wdt Wrote: >The boot loader installed in the SPI from the factory allowed booting from USB.
Do you have any details about this? what version?
Did you make a backup of it before overwriting it with towboot?
uboot is more like firmware, it is hardly a boot
when the OS is loaded, that is a boot
From what I read, Tow-Boot was a fork of UBoot, so they're both filling the same niche and doing the same thing.  It just makes more of the storage devices available for booting an OS.  Also, from what I saw when trying to move to a different OS for my PBP, the version of UBoot installed in the SPI at the factory only guarantees to boot with Manjaro, and that others have had problems flashing and booting other operating systems with that version of UBoot.
Regardless of the semantics, the steps I outlined above do work and should work for pretty much any OS you want to dd back over your eMMC module.
RE: 6/22 run of PBPs - is reimaging eMMC with new OS possible still? - by Crewchief - 08-24-2022, 08:20 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 458 12-07-2023, 03:11 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,030 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,575 04-01-2023, 03:22 PM
Last Post: TRS-80
  Fix for Armbian not booting on PBP from eMMC agreenbhm 7 3,965 04-01-2023, 02:58 PM
Last Post: TRS-80
  My installation guide starting from messed up eMMC Besouro 0 887 12-19-2022, 01:01 PM
Last Post: Besouro
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,136 10-10-2022, 06:22 AM
Last Post: maxjrh
  Debian emmc installer db579 6 3,078 08-23-2022, 06:13 AM
Last Post: db579
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,547 08-18-2022, 11:26 PM
Last Post: calinb
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,631 08-18-2022, 11:47 AM
Last Post: Bemo
