eMMC frequently not found by Linux kernel (especially on low battery)
(06-20-2020, 02:38 PM)Arwen Wrote: Note that if you changed the kernel, and other files in "/boot" to ones in Debian, that can prevent Manjaro from booting.
What I did was replaced the U-Boot binaries on disk with "dd" using the default Debian ones, not the files in "/boot".
Sure, that's also what I did. I had not changed Manjaro on the SD card at all. As I understood it from the docs, U-Boot is loaded from the internal eMMC, if available, and only from the SD card if the eMMC is disabled (or probably also if it does not contain U-Boot). But even U-Boot from the eMMC, if configured appropriately, can boot a kernel from the SD card. mrfixit2001's U-Boot, the one I mentioned in this thread's first post, is doing exactly that. Apparently Debian's U-Boot is not configured to do so.
For some reason I had used an older version of mrfixit2001's branch initially: my link goes to 1.1. Now going back to his U-Boot to have the flexibility of sometimes booting Manjaro from SD card, sometimes Debian from eMMC, I opted for version 2.0. I modified his mrfixit_update.sh:
diff --git a/pinebook/filesystem/mrfixit_update.sh b/pinebook/filesystem/mrfixit_update.sh
--- a/pinebook/filesystem/mrfixit_update.sh
+++ b/pinebook/filesystem/mrfixit_update.sh
@@ -1,7 +1,7 @@
#!/bin/bash
DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" >/dev/null 2>&1 && pwd )"
-myver="0.0"
+myver="1.99"
if [ -f /usr/share/myver ]; then
        myver=$(cat /usr/share/myver)
fi
@@ -65,10 +65,10 @@ fi
if [[ $myver < 2.0 ]]; then
        # Leave the current kernel version's modules folder in place so that it can be used as the backup kernel
-      echo "Updating Kernel Modules to 4.4.213..."
-      KER="$(uname -r)"
-      find /lib/modules -mindepth 1 ! -regex '^/lib/modules/'$KER'\(/.*\)?' -delete
-      rm /lib/modules/4.4.213 -r
+#      echo "Updating Kernel Modules to 4.4.213..."
+#      KER="$(uname -r)"
+#      find /lib/modules -mindepth 1 ! -regex '^/lib/modules/'$KER'\(/.*\)?' -delete
+#      rm /lib/modules/4.4.213 -r
        mv $DIR/4.4.213 /lib/modules
        echo "Updating U-Boot..."
Actually it seems like DigiKam in Manjaro is now supporting external MySQL databases! Smile So my main reason for having switched to Debian is gone.
And again Manjaro provides much better video playback support. Even full-hd is now working on Youtube (with Chromium).
Still, this u-boot situation is odd. Maybe I should install the version from Manjaro? The version as shown by pacman is: uboot-pinebookpro 2020.07rc4-1.1
I don't even know if I'll continue to have these eMMC not found issues, with the different u-boot I'm using again. I'll report here as soon as I know more.
RE: eMMC frequently not found by Linux kernel (especially on low battery) - by v-man - 06-21-2020, 12:56 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 361 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,187 12-13-2023, 07:22 PM
Last Post: trillobite
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,550 09-07-2023, 09:38 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,999 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,519 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 673 07-13-2023, 05:21 PM
Last Post: owaspfap
  kernel module that supports usb-c hdmi alexandre 16 14,733 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Kali Linux for Pinebook Pro Luke 100 160,736 05-03-2023, 06:10 AM
Last Post: dachalife
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,532 04-01-2023, 03:22 PM
Last Post: TRS-80
