pinebookpro-debian-desktop-mrfixit-190905 - audio output very noisy
Sad
With pinebookpro-debian-desktop-mrfixit-190905 the audio output is very noisy.
I mean there is background noise in continue each time the audio output is used.
The noise disappears once the audio (sound, video) is over.
- the noise appears right after a flash of the image
- the noise appears after "MrFixIt Update Script" (+ reboot)
- the noise appears after "Update WiDevine ..." (+ reboot)
The noise is present with built-int speaker and with headset.
I do not have HDMI adapter.
Did you also get this experience?
Do you know how to resolve it?
Best regards
The speakers seem to work better with this OS: https://forum.pine64.org/showthread.php?tid=7920
(10-22-2019, 02:13 PM)zaius Wrote: The speakers seem to work better with this OS:  https://forum.pine64.org/showthread.php?tid=7920
Thanks for the reply.
0.9.14: gitlab-ci-linux-build-159 is still a bit noisy. However it is usable.
Best regards
I am using Ubuntu Mate and have this noise problem. But I have found that if you set the brightness of the screen to 100%, the noise disappear.
This is probably because the screen brightness is set using a PWM and this is sending electromagnetic noise.
We will have to see how to shield this.
  Official Debian support moonwalkers 63 52,704 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,428 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,201 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,711 09-07-2023, 09:38 PM
  Audio on Armbian Hobbes42 1 900 08-04-2023, 01:18 AM
Last Post: Humid Stylus
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,212 07-15-2023, 02:58 PM
Last Post: u974615
  Audio Driver on the pbp korreckj328 5 1,789 05-01-2023, 12:58 PM
Last Post: korreckj328
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 568 02-16-2023, 10:58 AM
Last Post: cowsay
  unsuccessful re-install of OS for PineBookPro Valiance 3 1,381 02-14-2023, 12:49 PM
Last Post: Valiance
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,316 12-09-2022, 12:43 PM
Last Post: as365n4
