PostMarketOs Plasma on PinePhone
Hello
 I need help. I have received my first PinePhone device (not dev-board).
I've used pmbootstrap to create and burn an image on a SD card for the device.
I selected pinephone as the vendor and pinephone as the codename.
I tried the following UI options: Phosh, plasma-mobile, hildon.
In all three cases, the phone powers up, and the PostMarketOS Logo Splash comes up, and it is suck there.
In the up left side of the screen, a console login prompts appears.
But, nothing else happens.
Can someone help me to figure out what I am doing wrong?
Danny
I would recommend working on the postmarketOS github as per the wiki.
But please update the wiki if you find out a better/different way.
If you have the phone connected to your computer while it's booting it should show up as a network interface. You can SSH in to the phone with username@172.16.42.1 (the username you've chosen in pmbootstrap). From there you should be able to get the kernel log with dmesg and the userspace logs with logread.
(01-02-2020, 02:50 PM)MartijnBraam Wrote: If you have the phone connected to your computer while it's booting it should show up as a network interface. You can SSH in to the phone with username@172.16.42.1 (the username you've chosen in pmbootstrap). From there you should be able to get the kernel log with dmesg and the userspace logs with logread.
Hmmm, it's not showing up on Windows. Is a special driver needed?
I can see usb0 on the phone with that IP address, but Windows 10 does not seem to recognize it.
  Freezing and force rebooting on PinePhone HHawks 4 4,867 05-02-2025, 09:04 AM
Last Post: HHawks
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 3 7,756 11-18-2024, 02:23 AM
Last Post: linmob
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 5,906 10-03-2023, 06:32 PM
  [Not Pinephone] Phosh Autologin LienRag 11 13,556 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  How to include desktop file and icon in a postmarketos package patrickMcDonald 0 3,370 07-27-2023, 12:34 PM
Last Post: patrickMcDonald
  installed postmarketos v23.06 no audio samlo 1 4,513 07-14-2023, 12:53 AM
Last Post: samlo
  Scanning with PostmarketOS AndyM 1 4,004 07-01-2023, 08:16 AM
Last Post: AndyM
  VPN for PostmarketOS publiclewdness 1 5,010 03-11-2023, 04:35 PM
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 5,001 02-11-2023, 08:19 AM
Last Post: acid andy
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 4,289 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
