Clusterboard MicroUSB, LEDs
Hello everyone,
my Clusterboard works great, however, I'm wondering about two things.
The various LEDs: Each slot has two LEDs near the network chip and one LED at the edge of the board. The latter one might be disk activity (?). Also, each board has an LED and the Clusterboard also has another LED near the ATX power connector.
The MicroUSB-Ports: They do not seem to be standard usb host ports; can they be used in armbian?
Regards
The two LEDs near the GbE PHY are the normal PHY LEDs you would have on a normal magjack/RJ47 socket, they can be configured via RTL8211E registers. The LED at the board edge it the 'System' LED you can use for whatever you want basically, e.g. heartbeat and is connected to PL7 GPIO as on the normal Pine64 boards... the LED on top of the SOPine module is the power LED for the AXP803 PMIC and just signals that it's primary input voltage is OK... the LED near the power connector is just a fixed power LED...
As for the USB ports, on Linux both are host ports... the USB-A is connected to USB0 and the micro-USB-A is connected to USB1, both are configured in host mode. You can use the micro-USB port with a host port adapter like for phones with micro-A ports...
(02-28-2018, 10:45 AM)xalius Wrote: The two LEDs near the GbE PHY are the normal PHY LEDs you would have on a normal magjack/RJ47 socket, they can be configured via RTL8211E registers. The LED at the board edge it the 'System' LED you can use for whatever you want basically, e.g. heartbeat and is connected to PL7 GPIO as on the normal Pine64 boards... the LED on top of the SOPine module is the power LED for the AXP803 PMIC and just signals that it's primary input voltage is OK... the LED near the power connector is just a fixed power LED...
Thank you for the detailed explaination!
Per default mode, the PHY LEDs also blink when there are no boards inserted; this is why I initially did not think they were PHY LEDs. For the System LED I found /sys/class/leds/system_status where "echo 0 > brightness" will turn off; value 1 will turn on. :-) Also, "cat trigger" shows various triggers.
Regards
  Managed Ethernet switch on the Clusterboard dsimic 6 16,281 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 14,124 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 5,353 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 27,437 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 11,877 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 5,516 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 35,068 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 6,806 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 14,176 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 10,628 08-15-2020, 07:31 AM
Last Post: poVoq
