Wifi/BT module with/without an antenna?
Hi everybody,
just a quick question - does the Wifi/BT module contain an antenna? The Pine64 shown in the youtube videos has some kind of an antenna/wire.... Just wondering whether I should buy an external antenna with U.FL connector or it comes with the module... there is no info about it on the survey page...
BR,
Peter
(02-18-2016, 01:59 AM)lianaboy Wrote: Hi everybody,
BR,
Peter
The WiFi/BT module does come with a short antenna wire, yes.
BR,
Peter
We use such design due to the wireless performance better than on-board PCB antenna but cost slight higher.
The antenna is 15cm long.
Could the end piece of the antenna be sticked to the top piece of the acrylic enclosure with double sided tape? Would it have effect on the range?
(02-18-2016, 03:18 PM)RaspiBit Wrote: Could the end piece of the antenna be sticked to the top piece of the acrylic enclosure with double sided tape? Would it have effect on the range?
Yes it can. Try to get as "clear space" as possible for antenna and you will have good range.
Does anyone know if the WiFi module sold on the website easily connects to the Pine computer? Do it yourself? Are any additional wires required?  Will it fit together inside one of the enclosures (the clear one)?
The WiFi/Bluetooth module slots easily into place, you just push it on and you're done. No additional wires required. And yes, it will fit inside the enclosure (clear one) without problem.
Working on my Mario Enclosure for the PINE (in aluminium) I got to thinking about the signal strength. I added possibilities for external antenna. But will this have any impact on the signal strenght? Or can I just use the supplied antenna inside the aluminium box? It would look much smoother without the external antenna.
  [split] Better WiFi/BT module? moriel5 3 10,637 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,801 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,389 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,276 07-30-2020, 04:53 PM
Last Post: S265
  Connecting an Antenna km782 1 5,276 04-15-2019, 02:26 PM
  Create a WiFi hotspot on Debian 8 JulianM 6 33,894 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,883 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,601 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 6,207 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,879 02-21-2018, 09:56 PM
Last Post: dkebler
