Connecting an Antenna
The signal strength is pretty weak so I would like to add an antenna.  I thought that the connector was u.fl so I ordered this:
https://www.amazon.com/HUACAM-5-8GHz-Dua...06WD7FZV4/
However, when I pulled the old wires off of the module and tried to connect the new one, the connector is too big.  Is the connector on the WIFI/BT module not u.fl?  What do I need to get to connect to this board?
Thank you
Actually, now I'm wondering if the connector on the module is w.fl?
(04-13-2019, 09:27 PM)km782 Wrote: The signal strength is pretty weak so I would like to add an antenna.  I thought that the connector was u.fl so I ordered this:
Thank you
The PINE-A64 Wifi/BT module connector is the U.FL type. Based on your Amazon link, my may received the iPEX type which is smaller connector than U.FL.
  Wifi/BT module with/without an antenna? lianaboy 8 16,316 02-24-2016, 01:20 AM
Last Post: Tarjei85
