Android 6.0 Tablet and TV (release candidate, maintained)
#71
wappi: any reason for doing that?
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#72
I have two devices connected to my TV. Somehow when both deviced are on, the CEC does not work for my rasberry pi based media center anymore. As long as CEC does not work for all TVs properly I would prefer to have it disabled.
#73
wappi: I will reconsider this
Releases:
Buy me a Beer
#74
wappi: here is your requested option: https://jenkins.ayufan.eu/job/android-6.0-pine-a64/21/
Releases:
Buy me a Beer
#75
It is working! Thank you for this quick fix. Now I am 100% satisfied. :-)
#76
Been awhile since I have run your Android TV versions, but today I installed and ran your newest Android TV 6.0 and as usual, it is fantastic.
There is one problem, that I can't seem to resolve. All my boxes connect through my Denon AVR so I get surround sound. With this version, there is no setting to make sure the audio uses the "HDMI" mode, so everything plays in stereo. All my other Android boxes have a setting to select, PCM, auto or HDMI, but missing from this build.
So, if you can bring back the setting for the audio output, that would be awesome.
thanks.
#77
After I burned the image (6.0 TV) on the SD and then put it on the Pine64 (2 GB), the red led lights for some seconds and then turn off. Tried several times to turn on, but I obtain the same result everytime. No problem with Android 5.1.1. Possibly soultions?
#78
Check the "uEnv.txt" file, "disp_mode=1080p60" may be missing the space just before "disp". It should read:
" disp_mode=1080p60"
#79
console=ttyS0,115200n8
selinux=permissive
enforcing=0
optargs=no_console_suspend
kernel_filename=kernel
initrd_filename=ramdisk.img
hardware=sun50iw1p1
# INFO:
# To enable one of below options,
# uncomment them by removing # in front of name
# To use android recovery:
# initrd_filename=ramdisk-recovery.img
# To enable LCD:
# pine64_lcd=on
# Configure contiguous memory allocation
# This maybe required to be enlarged for 4K displays
cma=384M
# To change HDMI display mode:
# disp_mode=480i
# disp_mode=576i
# disp_mode=480p
# disp_mode=576p
# disp_mode=720p50
# disp_mode=720p60
# disp_mode=1080i50
# disp_mode=1080i60
# disp_mode=1080p24
# disp_mode=1080p50
disp_mode=1080p60
# disp_mode=2160p30
# disp_mode=2160p25
# disp_mode=2160p24
# To enable DVI compatibilty:
# disp_dvi_compat=on
# To enable CSI camera:
# camera_type=s5k4ec
# camera_type=ov5640
# Configure ethernet speed
eth0_speed=auto
# eth0_speed=1000
# eth0_speed=100
# eth0_speed=10
# Disable HDMI CEC
# hdmi_cec=0
# Enable experimental HDMI CEC driver
hdmi_cec=2
This is my uEnv.txt. Where is the problem?
#80
This part:
disp_mode=1080p60
Add a space just before "disp"
Shocked Remote for Android? liodra 18 29,754 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,860 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,000 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,071 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,626 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,347 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,977 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,556 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,399 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,685 01-07-2019, 01:21 AM
