Wifi dongle issues
Hello, All
I tried connecting my wifi dongle to a USBC adapter before plugging into the pinetab2. No results. The dongle came with drivers but I have no way to use a cdrom disk. Should I get a plug n play dongle? Is it a problem w the USBC adapter?
Your thoughts will be greatly appreciated.
Deckard
what dongle is it and what os are you running on your pt2? you do probably just need to install the drivers, but you may be able to use another computer to download them to a thumb drive and then move them to the pt2. you likely won't need to find a disk drive for the included cd.
if you look up the dongle's specs you should be able to find the chipset and then use the chipset to search for your os' drivers. then you can download them, transfer them with the usb drive, and install/reboot to use the dongle.
you should update your os once you get the driver's installed, as there are now drivers for the built-in wifi.
I strongly doubt the CD-ROM contains working drivers for Linux aarch64 anyway. Probably not even Linux x86_64, only Windows and maybe macOS.
Also note that the builtin WiFi on the PineTab2 should work with current kernels and you should not need an external dongle at all (unless you want to use some specific feature like "monitor mode" that needs specific chipsets).
  First time user experiencing weird keyboard issues kendew 5 11,172 06-19-2021, 08:14 AM
Last Post: rotwang
  RockPro64 ethernet issues: DMA engine initialization failed slowcamp 1 6,076 04-26-2021, 06:03 AM
Last Post: slowcamp
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 5,683 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Cannot charge and NO Wifi? jiapei100 3 8,747 06-27-2020, 02:11 PM
Last Post: jiapei100
Bug WiFi enabled but refuses to connect cardboardmaster 6 13,720 06-02-2020, 11:56 PM
Last Post: pfeerick
  WiFi issues Pinebook Pro sunnystormy 6 15,080 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 19,100 06-13-2019, 04:25 PM
Last Post: evilbunny
  Network issues, possibly not booting? [Solved] Ryanteck 3 8,577 06-17-2017, 11:01 AM
Last Post: xalius
  Is the Wifi module working? clawinus 8 18,138 11-23-2016, 10:09 AM
Last Post: clawinus
  how to install Wifi/Bluetooth module danlcarr 2 7,068 10-08-2016, 09:59 PM
Last Post: danlcarr
