Cannot charge and NO Wifi?
I just received my PINE64 Community Edition: UBports Limited Edition Linux today. And it seems it got some issues:
1) It seems the power on my laptop's USB port is NOT powerful enough to power PINE64 up, PINE64 always restart after I see the PINE64 logo.
2) Therefore, I tried to power PINE64 up using USB power adaptor with the delivered Type C cable. Now, PINE64 boots into Ubuntu 16.04. However, it's NOT changing at all. the Battery Charge Level sticked to 0%, no matter how many hours I left PINE64 for charging. As long as I disconnect the Type C cable, PINE64 is out of power and shut down right away.
3) What'e even more weird. In Settings->Battery, there is even choices for Wi-Fi and Bluetooth? What's that for?
4) And in Settings->Wi-Fi, there is ONLY 1 option: Previous networks , PINE64 won't be able to show Wireless network around.
So, in sum: PINE64 ALWAYS stick to batter charge 0%, and Wi-Fi doesn't search wireless network at all.
Did anybody have those issue as well? Is there a way to let me reflash Ubuntu onto PINE64 from scratch ?? Say, how can I flash Ubuntu 20.04 onto PINE64 ?
Thank you very much. Looking foward to have some fun on PINE64.
Pei
Welcome to Longer Vision
https://www.longervision.ca
Bump
I just got my phone today and I am having the exact same issue.
You have to remove the tape from the battery contacts in order to get Wi-Fi and charging working.
Picture of tape on the battery contacts:
https://wiki.pine64.org/images/6/62/Pine...tery3.jpeg
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
Problem solved... Thank you very much... I need to remove the tape...
  Wifi dongle issues Deckard 2 3,398 01-13-2025, 12:34 PM
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 25,155 03-12-2021, 07:08 PM
Last Post: cmicallef
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 5,799 02-02-2021, 12:13 AM
Last Post: PineSupporter
Bug WiFi enabled but refuses to connect cardboardmaster 6 13,971 06-02-2020, 11:56 PM
Last Post: pfeerick
  WiFi issues Pinebook Pro sunnystormy 6 15,278 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 19,466 06-13-2019, 04:25 PM
Last Post: evilbunny
  Is the Wifi module working? clawinus 8 18,415 11-23-2016, 10:09 AM
Last Post: clawinus
  how to install Wifi/Bluetooth module danlcarr 2 7,198 10-08-2016, 09:59 PM
Last Post: danlcarr
  WiFi module causes boot loop BnEc 17 42,197 09-24-2016, 09:12 PM
Last Post: pfeerick
  LCD works only when Wifi Module not installed nesalot 2 7,557 09-03-2016, 03:53 AM
Last Post: nesalot
