No WIFI network discovery in any manjaro installation (but works on fedora)
Does anybody have an advice about activating the wifi network discovery on fresh manjaro installation (or when running from SD card)?
When I got the PBP the wifi worked on manjaro but soon after started to show no networks and failure in activating the wifi network interface. I reinstalled manjaro and separately ran from SD card and it's all the same. I also made sure the wifi hardware switch is not activated. When running fedora on an SD card the network discovery works fine.
What can I do to resolve this?
(01-24-2021, 01:01 PM)pineitup Wrote: Does anybody have an advice about activating the wifi network discovery on fresh manjaro installation (or when running from SD card)?
Were you ever able to resolve this?  I just flashed Manjaro Lomiri to an SD card and I'm also having the same issue.  Actually, I got the wi-fi working initially but not for long and could never get it to reconnect.  Restarted phone, toggled Wifi on and off in software and the hardware switches, still nothing.  Wi-fi works fine on Plasma Mobile, PostmarketOS, and Mobian
  Wifi dongle issues Deckard 2 3,119 01-13-2025, 12:34 PM
Information Star64: Armbian Installation Der Geist der Maschine 5 13,868 06-03-2023, 01:26 PM
  New User use PineBookPro default OS Manjaro clessard 0 3,131 07-02-2022, 09:01 AM
Last Post: clessard
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 3,321 05-23-2022, 08:49 AM
Last Post: 98cwitr
Question Jerky wired network ale 1 4,418 04-11-2022, 03:40 AM
Last Post: ale
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 7,843 05-25-2021, 11:05 AM
  Email addresses in Claws for Manjaro-Arm James Good 6 12,884 08-30-2020, 07:52 PM
Last Post: bcnaz
  Cannot charge and NO Wifi? jiapei100 3 8,727 06-27-2020, 02:11 PM
Last Post: jiapei100
  brand new manjaro PBP - pacman PGP import failure shindagger 0 3,588 06-18-2020, 07:19 AM
Last Post: shindagger
Bug WiFi enabled but refuses to connect cardboardmaster 6 13,698 06-02-2020, 11:56 PM
Last Post: pfeerick
