Pinetab2 stays dark / won't boot
Hi everyone,
my Pinetab2 suddenly stopped working after around 4 weeks of minor usage.
The main symptom is, that the display stays complete black when trying to power on.
As Pine64's support is unfortunately not very helpful and pointed me to the community, i'd really appreciate your help.
I was able to get the following out from UART-console:
## Checking hash(es) for Image u-boot ... sha256+ OK
## Checking hash(es) for Image fdt-2 ... sha256+ OK
## Checking hash(es) for Image atf-2 ... sha256+ OK
## Checking hash(es) for Image atf-3 ... sha256+ OK
## Checking hash(es) for Image atf-4 ... sha256+ OK
## Checking hash(es) for Image atf-5 ... sha256+ OK
## Checking hash(es) for Image atf-6 ... sha256+ OK
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-594-g7f859117f:cl
NOTICE:  BL31: Built : 04:51:16, May 11 2023
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid 220114
INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2023.07-1-00043-g2e0e11b8e6 (Jul 01 2023 - 07:59:26 +0000)
Model: Pine64 PineTab2 v2.0
DRAM:  8 GiB (effective 7.7 GiB)
PMIC:  RK8170 (on=0x80, off=0x04)
Core:  321 devices, 25 uclasses, devicetree: separate
MMC:   mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0
Loading Environment from nowhere... OK
In:    serial@fe660000
Out:   serial@fe660000
Err:   serial@fe660000
Net:   No ethernet found.
Hit any key to stop autoboot:  0
Card did not respond to voltage select! : -110
** Booting bootflow 'mmc@fe310000.bootdev.part_1' with script
Booting from eMMC
Loading kernel...
Failed to load '/Image.gz'
Uncompressing kernel...
Error: Bad gzipped data
Loading initramfs...
7685356 bytes read in 68 ms (107.8 MiB/s)
Loading dtb...
120036 bytes read in 41 ms (2.8 MiB/s)
Booting...
Bad Linux ARM64 Image magic!
Boot failed (err=-14)
No ethernet found.
No ethernet found.
  PineTab2 spec for ddr and rth 0 3,096 12-09-2025, 08:28 PM
Last Post: rth
  Pinetab2 not starting Corconegre 12 24,628 07-25-2025, 03:04 AM
  What is the state of the PineTab2 today? Arcikks 2 4,456 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 17,194 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 4,174 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 7,372 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 5,805 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 2,856 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 2,788 10-14-2023, 05:48 PM
Last Post: lockedpotato
  pinetab2 booting when adapter connected Ome Ko 16 16,421 09-15-2023, 11:45 PM
Last Post: Ome Ko
