Black screen by start up
I wasn't clear, I am booting with an sd card in place. Since the problem seemed to be because I had screwed up the nmcli configuration every time the boot got to the point of establishing the network with the bad configuration it would freak out and stop booting. So I finally did the obvious and unplugged the network cable and the system booted fine thus allowing me to fix the nmcli configuration. Da!
Thank you for your prompt attention. I appreciate it.
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 308 02-23-2024, 04:22 PM
Last Post: tuxxpine
  PBP blank screen after updating Manjaro Franko 6 2,026 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,007 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,108 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,754 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 4,763 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 13,931 08-24-2021, 04:25 PM
Last Post: bkenn
  Flickering black window when opening settings Edgars10 0 1,357 06-06-2021, 05:42 AM
Last Post: Edgars10
  Screen refresh delay with kernel errors shawnanastasio 31 38,815 04-27-2021, 02:57 AM
Last Post: james64
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 19,683 01-27-2021, 10:48 PM
Last Post: rimaille
