Will the PineTime have a timer for the Pomodoro technique?
The title of the post says it all I guess. I'm interested in a Pomodoro style timer which vibrates (to avoid annoying people) every X minutes.
I have a sealed version with InfiniTime 1.2.0, but if someone experienced says for example that on Wasp-os it's easy to write the program yourself, I can try to switch to it.
If nothing else you should update InfiniTime - there have been significant fixes since 1.2.0
https://github.com/InfiniTimeOrg/InfiniTime/releases
How easy it would be to write a timer app will depend on your skill level. There are already timers/alarms in both InifiniTime and WaspOS that will give you most of what you need.
Pomodoro is really cool!
it looks like there will be some pomodoro app available soon, but on wasp-os
Away
  Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 3 5,406 06-06-2026, 03:33 PM
Last Post: oscar-gardiazabal
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 5,265 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 4,428 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 11,384 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 6,388 07-30-2025, 11:44 PM
Last Post: karthick
  PineTime charging issues - connecting pins black gsoundsgood 2 4,602 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 7,488 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 11,783 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 7,599 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 3,003 01-31-2024, 11:57 AM
Last Post: tynstar
