External display doesn't work in TwisterOS (Armbian)
Question
Does anyone know how to make an external display work in TwisterOS (which is based on Armbian)? The external display works in Manjaro, but not TwisterOS. Here is the only offending line I could find in dmesg:
[  10.658203] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] *ERROR* Enable dp failed -19
I have attached the rest of dmesg's output, in case that is useful info.
Thanks!
.txt   dmesgoutput.txt (Size: 55.19 KB / Downloads: 589)
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,213 08-09-2025, 06:53 AM
Last Post: Sb2024
  Armbian fix, current version now works Sb2024 0 2,989 08-08-2025, 08:49 AM
Last Post: Sb2024
  No external monitorvia USB-C over Dockingstation bnjmnhg 17 20,868 01-17-2025, 06:02 PM
Last Post: Dendrocalamus64
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,381 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  USB 3 port not working with Armbian zaius 3 6,173 11-13-2023, 01:54 PM
Last Post: zaius
  Sleep and external display - Are there any options? chris88233 7 8,861 09-04-2023, 09:03 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 17,613 08-31-2023, 04:20 PM
Last Post: TRS-80
  Audio on Armbian Hobbes42 1 4,283 08-04-2023, 01:18 AM
Last Post: Humid Stylus
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 9,631 04-01-2023, 03:22 PM
Last Post: TRS-80
  Armbian 22.02 release announcement TRS-80 22 30,944 04-01-2023, 03:19 PM
Last Post: TRS-80
